- May 4, 2018
VW unveiled their all new offering in the European crossover B segment.
Basically this is a VW Polo with a 4 cm higher ground clearance and additional 6 cm higher driver's position which results in 10 cm higher position measured from the ground. All that lead to a much better space efficiency in comparison to Polo.
Rear bench is sliding one.
For South American market it will have longer wheelbase than in Europe. But in Europe that solution will be explored by future Škoda crossover.
It will offer a base 6.5" infotainment screen with 8" as an option. Also there will be an an option for virtual cockpit which of course can display navigation. But CPU is to slow to simultaneously run navigation on both virtual cockpit and infotainment screen.
Platform is MQB A0. So there will be no independent rear suspension or AWD.
Dimensions are:
Dimensions are:
- length 4107 mm
- height 1558 mm
- width 1781 mm
- wheelbase 2566 mm
- 1.0 TSI 95 HP
- 1.0 TSI 115 HP
- 1.5 TSI 150 HP
- 1.6 TDI 95 HP
