cygnus
- Oct 31, 2018
As I referenced in an earlier thread (Next L Car Hybrid Electrification clue - 2024 Corvette E-Ray is _not_ a PHEV) I have reason to believe that the Inline-6 engine can be paired with a mild-hybrid (MHEV) setup to achieve high-performance. STLA also has experience within PHEVs, and has implemented this setup on other vehicles in the portfolio.
As a refresher, there are two hybrid setups used in industry -
1) Mild Hybrid (MHEV) - which has been around since the debut of the Prius. A battery offsets the largest strain on the ICE powertrain (initial movement from a dead stop) and captures energy during breaking. Mild-Hybrids integrate seamlessly with the internal combustion engine. This setup is today on the Ram 1500 with eTorque, so STLA is familiar with this implementation.
2) Plug-in Hybrid (PHEV) - as the name implies, this implementation typically accompanies a 10-20 KWh battery. There are some packaging challenges with this setup - it can't be easily integrated with a pickup, for example. But STLA has managed to pair a battery with the 2.0L engine offered on the 2022+ Grand Cherokee, Wrangler, and also has a new implementation with the Dodge Hornet.
The question then becomes - will we see implementations of PHEVs or MHEVs on future Dodge, Jeep, and Ram vehicles?
My guess is that the answer this question is yes - we will see both.
PHEVs will be reserved for top level trims - the battery is the most expensive part of the setup, and PHEVs have much larger batteries than MHEVs. There will also be a 'push boost' option where it uses the battery for quicker acceleration. You saw this already with the Dodge Hornet. My guess is that you'll see MHEVs on all other trim levels (cheaper to implement).
So when will we see these PHEV and MHEV implementations?
You'll see it first on the Charger/Challenger. I'm really scratching my head as to whether the Charger/Challenger will have the PHEV paired with the Inline 6. If Chevy can do a high performance MHEV, I wouldn't be surprised if Dodge chases them with something similar (Inline 6 MHEV). To be frank, I don't know if STLA is ready to make PHEVs in volume until 2026 or later.
It's possible that the Ram refresh could have an updated eTorque implementation for their 2024 MY. It's getting the plain jane I6 for the 2023 MY (which has zero advantage over the Hemi, and no one will buy it).
TBD on whether the Wranger/Gladiator refresh will have it. Not sure if the electrical setup for either will support it with an entire redesign of the electrical subsystem. But the refresh has to carry Wrangler/Gladiator until the next full redesign (2027), so it may warrant the investment.
Grand Cherokee Refresh in 2026/2027 would be the earliest you would see it on WL74/W75.
