- May 4, 2018
With the Jeep Grand Cherokee L's new setup, the ball joint was moved to a virtual point In the past, the pivot point was inside the vehicle, between the wheels. Placing the virtual ball outside the wheels gives the vehicle more lateral stability.
"By moving the virtual ball more outboard, the vehicle is less sensitive to varying road inputs and vibrations to the driver, also providing additional stability and on center steering performance," Grado says.
Whole article at: The 2021 Jeep Grand Cherokee L Has a Fascinating Trick to Improve Its Handling
