codes PO108, PO308, PO300
lwlambert
Age
79
Trying to deal with these codes. I disconnected my new MAP sensor that i installed at the plug and no difference from when it is pluged in. should that happen. wondering if the MAP sensor is defective. It was idleing high and just happened to wiggle the wires at the MAP sensor and a big change in the idle ??? Should not be happening right?
