2020 Cadillac Escalade spied for the first time
The big news is an independent rear suspension
Cadillac is expanding its crossover and SUV range with a new three-row XT6, but that doesn't mean it has forgotten about the one that started it all. As seen in the above photos, the company is testing a new version of the Cadillac Escalade. It's well-covered, but there are a number of details that we can make out.
We'll get to what we can see of the design in a bit, but the big news is the suspension. Like the new Tahoe we previously spied, the 2020 Cadillac Escalade will have an independent rear suspension replacing the solid axle set-up that GM's full-size SUVs have always possessed. Its rivals from Ford/Lincoln went independent long ago. We can't underline enough how much of a difference this will make. Handling should be less cumbersome and the ride will be smoother and less prone to jiggling over bumps. It would be improved even further if Cadillac continues to offer magnetically controlled shocks as standard. Inside, the third-row should be positioned lower, thus lowering the current sky-high load height and resulting in a third-row that's actually habitable. In other words, the Escalade won't be so archaic.
You can see the visual differences between the new (top) and current (bottom) designs below.
dims
dims
Now, as for the design, our best clue to the new Escalade's design is in the grille. The flashy slatted chrome grille of the current model is gone and in its place a more modest mesh grille with little studs pushed to the front. It's very much like the grille found on the new CT6 and XT4. Also, like those two vehicles, the headlights appear to have more horizontal elements than the very vertical examples on the current Escalade.
The rest of the SUV is harder to make out. The profile is very similar to the current one, and will surely be shared with the Chevy Tahoe and Suburban and GMC Yukon models. The rear features new rectangular exhaust tips nestled into the rear bumper. The taillights will likely continue to stretch up the rear pillars.
Like the suspension, the Escalade will continue to be generally mechanically the same as the aforementioned Chevy and GMC versions, albeit with the best parts standard. The updated 6.2-liter V8 with Dynamic Fuel Management first introduced on the Silverado and Sierra will likely be the standard engine. It will then be paired with the 10-speed automatic transmission.
With the new Navigator so widely impressing in reviews and in sales, this new Cadillac Escalade will have to step it up. From what we see here, it looks to be on the right track.
It is rumored that a V-version will come.
Whether it is the twin turbo V8 or the LT4 that will have to wait and see.
