2013 caravan AC issue after disconnecting battery.
browlciba
I have a 2013 Grand caravan SE, I disconnected the battery to 192.168.1.254 inspect the power steering lines running beneath it.
After reconnecting everything, the rear defrost light flashes for a minute or two and the heating or cooling does not work. After a couple of minutes everything works normally.
I have done some Googling and found people with the same issue but have found no clear an 10.0.0.0.1 swer for the problem.
Any help is most appreciated.
UN4GTBL
I believe it's recalibrating when the lights are flashing.
As long as it goes back to working normally, all should be good.
